72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> How to cut a section in an angle, other than 90 deg (revit 2012)
![4 Stars: 1 Votes](/images/stars_4.gif) |
I wanted a section in an angle, not a straigt line. split segment lets me cut only in 90 degrees, is there any other way?
Rotate the section cut line, is that what you mean?
no, when u choose split segment for section line, that part cuts vertically right? I want that segment to be in some other angle...
No , the break portion of the shift has to be perpindicular to the section cut.
Removed Banked angle from sloping Pads |
Tue, Nov 3, 2015 at 4:17:31 AM
Variable Angle Door Swing breaks at 150° |
Fri, Sep 12, 2014 at 4:39:10 AM
Revit Architecture 2012 - Section shows view from behind cut line |
Thu, Jan 10, 2013 at 12:38:20 PM
Aligning text a section head |
Fri, Mar 2, 2007 at 1:17:11 PM
1 deg pitch |
Thu, Oct 13, 2005 at 2:28:32 AM
Members: | 2016954 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
