37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> nested family in project will not tag
Sat, Jul 9, 2011 at 2:52:12 PM | nested family in project will not tag
precast100
I have a project that has a family in it. revit structure 2010
The family has separate families in it.
I need to tag the hardware which is set up as a connection.
Thanks for your help in advance
Sat, Jul 9, 2011 at 2:54:03 PM | nested family in project will not tag part two
precast100
added 2 molre files
Sun, Jul 10, 2011 at 8:51:59 AM | nested family in project will not tag
3.5 Stars: 395 Votes
I did not open your files to check this.  In order for nested families to be taggable, the nested family has to be set to shared.  Open the nested family in the family editor and check that setting.
Sun, Jul 10, 2011 at 12:19:16 PM | nested family in project will not tag
precast100
Basic question.
Family one is a flat plate with studs on it  call it CHILD ONE.
Family two is a concrete panel call it CHILD TWO.
Project is called PROECT THREE.
CHILD ONE is loaded into Child TWO.
CHILD TWO is loaded into PROJECT THREE.
Both CHILD ONE AND CHILD TWO are set as shared
Question can CHILD ONE be tagged and scheduled in PROJECT THREE.
Thank you in advance,
Mon, Jul 11, 2011 at 7:06:28 AM | nested family in project will not tag
I don't understand why you ask the question ... Please try before you ask.
Mon, Jul 11, 2011 at 9:41:53 AM | nested family in project will not tag
precast100
problem solved
Thanks
Tagging equipment nested in casework family
Wed, Aug 1, 2012 at 3:32:56 PM
Multiple Nested Category Familiy Tags
Wed, Jan 30, 2013 at 4:02:47 PM
Nested Family Parameters in Project Bug?
Thu, Nov 13, 2014 at 12:31:00 PM
Nested Families....
Thu, May 3, 2007 at 3:38:42 PM
Nested door family - tags wil only show in elevation view?
Mon, Aug 9, 2010 at 9:53:32 AM
Page generation time: 5.0173
