37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> insert pixel images vertically
Sat, Jul 9, 2011 at 11:21:25 AM | insert pixel images vertically
fosterbill
Hey there,
I got a few questions towards displaying images in revit.
is there a way to display horizontal floor plans and vertical sections in 3D space and the same trace like in SketchUp? is there a certain plugin or can someone tell me how to manage that manually? Is it possible to insert pixel images vertically in revit?
Thanks in advance!
Bill
Sun, Jul 10, 2011 at 9:08:25 AM | insert pixel images vertically
Not sure I understand the questions.  Why would you want a section in 3D space?  Just place the 2D view over the 3D view on your sheet.  If you mean a 3D section - yes, they are easy to create.  Search the forums for this process.  Two methods, section box an align to view.
For the rotated image.  Did you try rotating the image in Revit, I have not.  If that doesn't work, the rotate the image outside revit before importing.
Wed, Jul 13, 2011 at 4:57:53 AM | insert pixel images vertically
fosterbill
hey,
sorry but I messed something up while posting my question...What I was looking for, was an explanation HOW TO display horizontal floor plans and vertical sections in 3D space simultaneously...
greetings
Wed, Jul 13, 2011 at 6:39:06 AM | insert pixel images vertically
Again, you are not clear.
Remember, this is BIM, not CAD.  Everything is model based.  If you want 2D Cad based elements, you can place those in your model and see them in 3D.
Sat, Jul 16, 2011 at 5:21:02 AM | insert pixel images vertically
fosterbill
okay...so I digitized scaled plans...now while drawing, I need to blend or fade them...but how?
Sun, Jul 17, 2011 at 2:15:37 PM | insert pixel images vertically
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Fosterbill if you need to bend, transparent, or manipulate images your using the wrong software--> you can do that in photoshop or a similar program, then import back to revit to refine the design. I imagine you are trying to use jpeg scans from hand drawing , you can do that with decal ( check the help for how to use them). But to be able to show or place them in elevations, sections or even plans you need to host the decals--> create a generic in place model to host those planes (the decals) . Hope this clear your mind.
Image off by just a pixel - can't compile.
Wed, Dec 9, 2009 at 4:09:26 PM
Inserted images gets corrupted
Wed, Sep 30, 2009 at 8:07:36 AM
Images disappear!
Wed, Sep 23, 2009 at 9:29:38 AM
Raster Image Content Blank-2010
Wed, Aug 26, 2009 at 10:25:55 AM
after revit export to pdf the file is wrong scale
Sat, Nov 20, 2010 at 10:54:05 PM
Page generation time: 0.3181
