52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Pasting aligned from 3d view to 3d view
Fri, Jul 8, 2011 at 2:31:42 PM | Pasting aligned from 3d view to 3d view
leothelionator
When copying elements from one revit model to another, I apparently don't get the option to "Paste aligned from current view".  However, I notice that the elements tentatively show up as blue dashed lines in the exact spot anyway but there is no way to click a button to accept the tentative location; is there?
Once you click on the screen the elements move to the clicked location.  Instead I deliberately move the elements a few feet away before pasting, then try to move the elements back in the correct spot.  Pretty tedious.
Mon, Jul 25, 2011 at 10:36:31 AM | Pasting aligned from 3d view to 3d view
kcaparella
I have noticed the same tedious hangup. Unforutnately I have not yet found a workaround myself or online anywhere. I'm guessing the "move and place" method you (and I) are currently using is the "correct" method - although it would seem beneficial to just have an "accept placement" command as you stated. Best of luck! If you've come up with any other solutions I would love to hear them! - Kcaparella
Paste Aligned in Current View Keyboard Shortcut
Wed, Dec 17, 2008 at 6:14:42 PM
Masking Region in 3d views that´s Aligned to an Elevation View
Sat, Jun 18, 2011 at 8:40:05 AM
pasting aligned.
Fri, Apr 3, 2015 at 12:48:10 PM
View Title with reference on right side
Thu, Oct 3, 2013 at 3:12:18 PM
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:06 PM
Page generation time: 0.8379
