Forums >> Revit Building >> Tips & Tricks >> How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012
First I tried loading the curtain wall door from the library, and it seems like its not loading into my project.. i am not getting any sort of error message, i just cant find them in the components or door categories. This is my first time tryin to add doors wor the curtain wall
Curtain wall doors are not the same as normal doors. Create your CW, then in an elevation, select the panel where the door would be and replace the system panel with the CW door. You do not place these doors from the normal door tab.
Edited on: Thu, Jul 7, 2011 at 3:18:34 PM
curtain wall doors aren't doors that you place normally -- what you have to do is select an individual panel, and replace the default glazing with your curtain wall door. That's where you'll see it as an option. You might have to hit tab a few times to select a panel.
There are lots of topics at the bottom of this page regarding the matter.
Thanks a lot for the Help!! I love this site and all the support that members give, really appreciate it
Default Curtain Wall Door Flipping? |
Thu, Oct 13, 2011 at 4:44:49 PM
Curtain Wall Panel to Curtain Wall Door |
Mon, Jun 23, 2014 at 9:32:12 AM
Solid Wood Door in Curtain Wall ? |
Mon, Aug 31, 2009 at 4:38:08 PM
curtain wall door |
Tue, Jan 31, 2006 at 1:36:59 AM
External Glass Curtain Panel Problem |
Tue, Aug 12, 2014 at 8:05:35 AM
Members: | 2098038 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
