61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> How to Resize Room Tags in Revit Architecture 2012
Thu, Jul 7, 2011 at 12:21:33 PM | How to Resize Room Tags in Revit Architecture 2012
Rakesh
4 Stars: 1 Votes
I did a plan in 1:100 metric scale and i have place some room tags. Then when i change the scale to 1:200 the room tag is not resizing. The font is too big. How can I resize the tags?
Thu, Jul 7, 2011 at 12:39:52 PM | How to Resize Room Tags in Revit Architecture 2012
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
you will need to edit the family and modify the text in the family.  It is a good idea to have different room tags for different scales.  We have one full size room tag and one half size room tag.
Annotation objects scale according to printable scale.  They get bigger or smaller according to your view scale.
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Thu, Jul 7, 2011 at 1:04:24 PM | How to Resize Room Tags in Revit Architecture 2012
3.5 Stars: 395 Votes
I was just having a discussion in the chatroom about the term "text scaling".  I believe saying that text scales is an old CAD hold over because you had to scale your text to match the scale you would print at..  In Revit, text never scales (except model).  Text always prints the same size.  It is the model elements in the view that scale.
Thu, Jul 7, 2011 at 1:19:17 PM | How to Resize Room Tags in Revit Architecture 2012
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
WWHub: I agree, I am using old CAD terms and thought process, Revit annotation text does not scale it remains at printable size.
Thanks Hub
Thu, Jul 7, 2011 at 2:18:58 PM | How to Resize Room Tags in Revit Architecture 2012
Rakesh
4 Stars: 1 Votes
Thanks a lot for the help Smile
Invisible room tags (Revit MEP)
Fri, Jul 22, 2011 at 12:58:58 PM
Room Tags in Linked File
Mon, Aug 23, 2010 at 6:48:45 PM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
room tags revit 2013
Tue, May 14, 2013 at 5:22:15 AM
Page generation time: 1.8900
