96 Users Online (94 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walk through's on multi levels
Tue, Nov 22, 2005 at 3:06:38 PM | Walk through's on multi levels
wdesign
On creating walkthroughs on multi level buildings how do you go from one level to the next without breaking the path? Is there a way to merge two different paths? Thanks for any help, -D
Tue, Nov 22, 2005 at 4:49:21 PM | RE: Walk through's on multi levels
geoffy
Hi there. Yes there is a way to move through multi-levels. 1/ set the camera height each time you set a key frame- you can only set this at the time of placing a key frame, you can't go back and edit the camera height at a later stage (bummer) 2/ you can also "pan" the camera view if you use the "show path" option and then pick each key frame and move the cameras view point to the position you want. With this feature it allows you to "circle" around a building for instance. If you are going to fully render a walkthrough can I suggest that you break the file up into as many many files as you can and render those on separate machines and when you have the exported AVI files "splice" them back together with something like MS Movie Maker- this will speed up the overall rendering time. Hope this helps- if you need further help just ask. GY
Tue, Nov 22, 2005 at 4:56:56 PM | RE: Walk through's on multi levels
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I prefer to export the workthrough as JPG's that way if something does change i can just re-render the required frames instead of doing another AVI.
Wed, Nov 23, 2005 at 11:35:05 AM | RE: Walk through's on multi levels
wdesign
Great help and advise - Thanks
Thu, Nov 24, 2005 at 4:45:35 AM | RE: Walk through's on multi levels
Enran
Goeffy, ofcourse you can edit the camera height after you have finnished your path! The easiest way is when you are in 3D view, you rightclick on the camera view in the browser window and then you click "show camera", then you edit the walkthrough and select "path" from the dropdown menu, now you can move your path in x-y-z directions. Mr Spot, you should know this...
Thu, Nov 24, 2005 at 5:34:05 AM | RE: Walk through's on multi levels
orv
4.5 Stars: 7 Votes
Very nice Enran , it works very good, for going up to another level using the stairs making the avi.Nice work and tanks! i thing this is what wdesign is looking for! cya
Thu, Nov 24, 2005 at 5:12:17 PM | RE:
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting Enran - 2005-11-24 04:45:34
"Mr Spot, you should know this..."
I was letting Geoffy handle this one. I can't answer all the threads on my own... Thanks for picking up the slack.
Fri, Nov 25, 2005 at 2:23:06 AM | RE: Walk through's on multi levels
Enran
Sorry Mr Spot if I offended you, I am new here and only realized how many threads there actually are.
Thu, Dec 1, 2005 at 10:44:53 AM | RE: Walk through's on multi levels
wdesign
Exactally what I needed...Thanks
Thu, Dec 1, 2005 at 6:33:28 PM | RE: Walk through's on multi levels
geoffy
Enran, As my father used to say- "you learn something new every day" It had not occured to me to try editing the view path in 3D view. What a great way to do it, although I do like to try and get the camera height set when I place key frames and then "pan" the camera at a later stage in plan view but hey the way you do it isn't as important as getting the result you are after is it?. Thanks again for the tip. GY
Mon, Oct 3, 2011 at 10:32:01 AM | Walk through's on multi levels
#11
AlphaOjo
Hi!  Many thanks for the great information here...especially about the drop down menu for paths...I would have gone years without noticing that.
One more question: Is it possible to stop at one key frame along the path and look around?  Say the path ends at the rail of a balcony and I want to look down?
Editing Multi-Level Building
Wed, Jul 20, 2011 at 11:11:05 AM
Rendered Walk through
Mon, Nov 22, 2010 at 4:58:09 PM
Mysteriously Linked Levels in multi-level Building
Mon, Feb 8, 2010 at 3:01:48 PM
Walk thru
Wed, Apr 29, 2009 at 9:41:48 AM
walk through's
Thu, Nov 13, 2008 at 4:26:13 PM
Page generation time: 1.0295
