59 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Editing Families
Wed, Jul 6, 2011 at 10:31:09 AM | Editing Families
mcrowe
I am having really good results with adding brick detail to a window component I am working with on my model.  However, I am using extrusions to create the brick detail.  My only issue is that I also have keystones.  When I try to change the material of the keystone, it changes the brick material as well or vise versa.  Can anyone help?
Wed, Jul 6, 2011 at 10:42:54 AM | Editing Families
If you join extrusions in a family, they will become the same material.  I believe that might be your problem.
Wed, Jul 6, 2011 at 10:47:56 AM | Editing Families
mcrowe
how do i tell if they are joined?  When i highlight them they are seperate.  Also, for some reason the pattern on one of the extrusions will not show up when I import the component to my model.  However, the pattern shows up when I am looking at the family while editing it.
Wed, Jul 6, 2011 at 10:51:32 AM | Editing Families
mcrowe
nevermind, i jsut realized that the pattern will not show up unless I am modeling haha! but I still have the issue of material types wanting to be the same
Wed, Jul 6, 2011 at 11:28:56 AM | Editing Families
If you are still having problems then you don't have a clear understanding of materials.  In the family editor, each 3D model element can be assigned a material but the name of the material has to be unique.  In the material editor, the material is then assigned the appropriate graphics, render image and identity.
Also, remember this.  THE PROJECT RULES!   Once a material is defined in the project, it can only be changed in the project.  So if you assign the color red to a material in the family editor and load the family, then if you change that material to blue in th family editor, it will still be red in the project.  Solution ... delete the family and material in the project and reload, or simply change the material in the project.
Wed, Jul 6, 2011 at 12:43:07 PM | Editing Families
mcrowe
Thanks so much everyone, I figured it out with your help and it looks great!
Editing Families
Fri, Oct 8, 2010 at 12:02:03 AM
Help editing All in one Revit Content families
Mon, Dec 21, 2015 at 1:27:25 PM
editing families when creating new
Fri, Sep 9, 2005 at 3:17:20 PM
Changing call out families
Thu, Jun 5, 2008 at 6:26:22 AM
Complex Family Editing
Mon, Mar 9, 2015 at 1:01:45 PM
Page generation time: 5.5149
