67 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Schedules adding two different subtotals together
3 Posts No Rating |
Hi all,
I am scheduling Areas for Townplanning purposes. I have Existing and Proposed. The Areas in the proposed Schedule have actually been multiplied by 1.1 for flexibility in the approval.
The areas in the Existing Schedule are kept as the actual figures....now I want to add the Proposed Figure (multiplied by 1.1) and the Existing Figure....but when i try to do it, I seem to either get both figures multiplied by 1.1 or not multiplied at all. (ie. Proposed = 110m² / Existing = 100m².....total should be 110m² however i can only get 100m² or 120m²
The way i set up the 1.1 multiplier was (Area/1) *1.1 and called it "Gross Area"
Any ideas? Can i actually say i want the grand total from Proposed Gross Area to be added to Grand Total Existing Area (not Gross Area)?
TIA
Andrew
How to hide rooms in schedule,, show only subtotals? |
Tue, May 1, 2007 at 6:47:31 PM
Mass Schedule Subtotals for Large Project |
Thu, Feb 22, 2007 at 4:42:06 PM
ADDING WALL HEIGHT PARAMETER TO WALL SCHEDULES |
Mon, Aug 30, 2010 at 12:57:36 PM
Schedules |
Thu, Dec 10, 2009 at 10:27:43 AM
which parameters can have totals in schedules? |
Fri, Nov 8, 2013 at 10:37:49 AM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
