138 Users Online (137 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Exporting Renders in Revit 2012
Tue, Jul 5, 2011 at 3:31:34 PM | Exporting Renders in Revit 2012
cwright
After some searching I didn't readily see a post with this issue.  My apologies if it has already been discussed elsewhere.
I set my render to Printer and 300 dpi.  I saved the resulting image to the project as well as exported as a JPEG and BMP.  Both image files have a resolution of 96 dpi.  Using the Export Image option I was unable to get any other dpi aside from 96.  Changing the Raster Image Quality still results in resolution being 96dpi.  Changing the value there increases the overall Height and Width pixels of the exported image but not the resolution.
Any input is greatly appreciated.
Tue, Jul 5, 2011 at 11:23:25 PM | Exporting Renders in Revit 2012
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Export the renderings to pdf ... use cutepdf, primo pdf or Adobe pdf. There you can set the resolution to the same as you set when you render it (300 dpi is just fine, 600 dpi is just insane).
Tue, Jul 5, 2011 at 11:39:31 PM | Exporting Renders in Revit 2012
cwright
Thanks.
That was my next idea.  I'm wanting to export an image for a graphic artist to manipulate for a trifold flyer for my client.  I'll see if they can use a PDF.
Wed, Oct 3, 2012 at 1:30:54 PM | Exporting Renders in Revit 2012
meridian
how do i export to pdf? do you mean thru print?
i have cutepdf but it doesnt show up in the options when i export a image
Wed, Oct 3, 2012 at 1:38:29 PM | Exporting Renders in Revit 2012
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Yes, print to pdf. If cutepdf doesnt work, use primopdf. Its free to use aswell.
Wed, Oct 3, 2012 at 1:41:52 PM | Exporting Renders in Revit 2012
meridian
ok thanks
i did this but how do i check the resolution on the pdf?
Wed, Oct 3, 2012 at 2:03:16 PM | Exporting Renders in Revit 2012
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
In "properties" when primo pdf is selected to print you change there the resolution, in "advanced" button. Put there 300 dpi, it will looks nice and wont lose the lineweight. To double check if its printed properly, import the pdf file to photoshop, and check there if the size  is accurate.
Exporting to CAD from Revit 2012
Mon, Oct 8, 2012 at 7:30:49 AM
RAC 2012 crashing when exporting image [shadows on]
Sun, Jun 19, 2011 at 8:50:21 AM
Rendering on Revit 2012
Mon, Feb 18, 2013 at 4:29:20 AM
exporting point info from revit structure into a text file
Tue, Jul 24, 2012 at 12:20:44 PM
Renders - Revit 2010
Tue, Jul 20, 2010 at 5:17:02 AM
Page generation time: 1.6795
