91 Users Online (90 Members):
Forums >> Revit Systems >> Technical Support >> Exploding an Import Symbol (.dwg file)
I was wondering if there was a way to ensure that when you explode an import symbol of 2D lines, that none of them will disappear.
I did a little querying on the import symbol to see what the difference was between the lines that would disappear and the lines that would stay.
And what I noticed when I queried them was the info in the query dialogue box differed.
LINES WHICH DIDN'T DISAPPEAR:
Type: Line
Block Name: N/A
Layer: Joinery
Style by: Object
This "Style by: Object" was different with the lines that disappeared.
LINES WHICH DID DISAPPEAR:
Type: Line
Block Name: N/A
Layer: Joinery
Style by: Layer
If anyone knows how I can change the second line to a "Style by: Object", rather than layer, your help would be greatly appreciated.
Thanks.
If you explode a dwg, Revit changes the lines to Revit lines and names them according to how they are defined in the dwg. The problem with exploding DWG's in a project is that you can get too many linetypes. It is better to explode dwgs in a cleanup project where you change the lines to your defined linetypes then import / or copy paste from the cleanup project into your project.
No lines should disapper unless that type is turned off in VG.
Okay, thanks
We'll have a look at it.
HELP: getting "Import Geometry Not Visible" error message when linking DWG file |
Fri, Aug 17, 2018 at 8:29:02 AM
AutoCAD Import and Exploding |
Mon, Sep 16, 2013 at 3:07:19 PM
import to revit from autocad |
Sun, Mar 31, 2013 at 11:37:12 AM
dwg disappears after exploding |
Thu, Jun 28, 2012 at 4:47:26 PM
Import DWG problem with size |
Mon, Dec 6, 2010 at 7:33:32 PM
Members: | 2030754 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
