38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Revit Architecture 2012 Library?
Sun, Jul 3, 2011 at 2:58:02 PM | Revit Architecture 2012 Library?
uros19
Hi,
I just installed Revit Architecture 2012. In the 2010 I had windows, doors, walls, etc.... already when I installed it. In the new version I have nothing! ANd I cant find where the families are to load them? SO I can't put even a door or a window to my project without creating a new one or download it. Can someone Help please????
Thanks
Mon, Jul 4, 2011 at 5:50:56 AM | Revit Architecture 2012 Library?
4 Stars: 202 Votes
You need to check where Revit installed those folders, try in "c:\programdata\autodesk\RAC 2012\Libraries"
Mon, Jul 4, 2011 at 3:00:29 PM | Revit Architecture 2012 Library?
uros19
Well that's the problem, I don't have that folder strangly... I checked everywhere but nothing. Do you know maybe where can I find it to download?
Mon, Jul 4, 2011 at 10:47:49 PM | Revit Architecture 2012 Library?
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
if you dont find the library... you can hit load family, and go up on the tree folder (and see where the families are located).
When you are browsing for the route, try to be REALLY careful with the spaces and the upper case.
As example, ProgramData is different than Program data and Program Data.
Wed, Jul 6, 2011 at 7:50:42 AM | Revit Architecture 2012 Library?
uros19
Thank you for the help but I still can't find the families. I go to load family and search all over the folder of Revit 2012 and the possible folders where the files could be, but still nothing!!! The only thing to do I think is to Download somewhere the basic families..... but I can't find them on internet
Wed, Jul 6, 2011 at 7:58:58 AM | Revit Architecture 2012 Library?
The library should be part of your installation.  Make sure you can see all folders including system folders, then do a search of your system looking for files with a .rfa extension.
Fri, Jul 8, 2011 at 10:56:43 AM | Revit Architecture 2012 Library?
uros19
I finally got clever and reinstalled the program and now I'm full of libraries.... Still don't know what was the problem because there's nothing to mess about with during the installation. Anyway, THANKS guys for your help
Wed, Aug 31, 2011 at 5:30:10 AM | Revit Architecture 2012 Library?
joewallace
im also having this problem and i have tried re installing the programme but i still have no libraries and i cant figure out why
Thu, Jul 12, 2012 at 4:05:10 AM | Revit Architecture 2012 Library?
alb1no
The folder ProgramData is hidden, so you need to go to Control Panel/Folfer Options and under View tab check
"Show hidden files, folders or drives".
Sat, Sep 1, 2012 at 11:21:02 AM | Revit Architecture 2012 Library?
Modularan
I was having the same problem in 2013. Do as the above poster suggested and turn on view hidden folders
How to get more Materials in the library (Revit Architecture 2012)
Fri, Jul 8, 2011 at 1:01:22 PM
Import full Civil 3D 2012 model in Revit Architecture 2012
Thu, Jan 26, 2012 at 6:23:36 AM
Re-installing Revit Architecture 2011
Tue, Dec 13, 2011 at 1:26:19 PM
2012 mep material library
Sun, Nov 27, 2011 at 3:24:24 AM
Using 3D Studio Objects in Revit Architecture 2011
Tue, Sep 20, 2011 at 12:09:54 AM
Page generation time: 2.8242
