43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> material not showing in render.....plz help
Fri, Jul 1, 2011 at 6:49:26 PM | material not showing in render.....plz help
tej26
1 Stars: 1 Votes
i have downloaded a compnent wine barrel from this site itself......when rendered the material is not showing,i edited the family n assigned the material .....but it just come out plain white...plzz its urgent..help
Fri, Jul 1, 2011 at 11:02:57 PM | material not showing in render.....plz help
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
You must reassign a material ... this family was done in 2008 (when revit uses nxt renderer) . Check under manage/materials/ thematerials called "Wine Barrel - Wood" and "Wine Barrel - Bands" . Go to "render appearance"  tab and hit "replace" button. Select any wood material you need.
Check your help (F1 on revit), this forum and google about materials and revit 2011.
Sat, Jul 2, 2011 at 4:06:18 AM | material not showing in render.....plz help
tej26
1 Stars: 1 Votes
i did that....i am working in 2009  and i opened edit family and replaced the material....still not wotking ...Sad
Sat, Jul 2, 2011 at 5:44:28 AM | material not showing in render.....plz help
4 Stars: 203 Votes
There are lots of threads about this same issue in Forums but edit the family, go to materials and check what material (name) you have assigned to that family then remember: " PROJECT RULES ", when you load that family into project, go to materials and check if the material is correct like you want.
family material dont show in render
Wed, Dec 16, 2009 at 4:41:08 AM
Materials not showing in render
Wed, Jul 6, 2011 at 1:14:39 PM
using revit 2008 project in revit 2009...plz help
Tue, May 27, 2008 at 8:44:39 AM
Adding new render material
Wed, Nov 2, 2011 at 10:39:46 PM
Material scaling in cloud render
Wed, Oct 9, 2013 at 1:26:30 PM
Page generation time: 2.0803
