Forums >> Revit Building >> Technical Support >> Alter the way 2 joined roofs look in floorplan
86 Posts No Rating |
Hello All,
Is it possible tot alter the way 2 joined roofs, join? Like you can adjust wall joins? The problem can be seen in the attached drawing. I would like the different layers of the roof to all join eachother, so that a nice corner is visible.
Thanks!
Edited on: Thu, Jun 30, 2011 at 6:54:21 AM
Those "Layers" must have the same "Function" and the same "Material name" to join like you want.
Thanks,
these roofs are exactly the same. That's wy I was surprised too. Workaround; I didn't use the dormer function, but drew 2 roofs through eachother, and both cut them with a verticall roof opening. Works ok.
Hallo,
The workaround is not accurate all the time, so maybe in the meantime there's a solution to my original question? Another screenshot of 2 roofs (same rooftype) created with "join roofs" and the "dormer' commands.
Help!
View / Cut profile
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Hmm yes. But a lot of work (just tried) and as soon as my view range changes, I need to do it again. (in my example: 4 corners, makes 8 joins, with 4 layers = use the cut profile tool 32 times....)
Is there a specific reason why roof layers don't act as nice as wall layers?
show us a screen shot of the roof layers and their assigned functions.
Layers: (although playing with functions and boundary didn't make any difference...)
Roof Eyebrow Construction |
Wed, Jul 27, 2011 at 3:53:42 PM
Join Roofs not cutting roofs? |
Mon, Nov 28, 2011 at 6:53:32 PM
Problems joining roofs |
Fri, Apr 16, 2010 at 10:52:17 AM
need some help |
Fri, May 27, 2005 at 1:19:35 PM
Joining 2 Curved Roofs ? |
Wed, Sep 23, 2009 at 8:36:37 AM
Members: | 2101026 | Objects: | 23173 | Forum Posts: | 152295 | Job Listings: | 3 |
