Forums >> Revit Systems >> Technical Support >> Fills not plotting
1 Posts No Rating |
The filled regions on my computer are not plotting while they are plotting from my coworkers computer.
We are working on our second Revit project (total newbies) and we have the above issue. On our first project the issue was reversed and I changed the V/G settings as described on this thread and it fixed the issue on my coworkers computer.
But now it is on my computer. I have checked the V/G settings and they all appear to be the same. Even transfered the settings from the first project over and still they do not plot. They preview fine but do not plot. I have tried switching between vector and raster to no avail. What is going on?
Help and advice please?
Thanks,
A project is self-contained. All of the hatches and lines and settings are saved in the project file. So moving it from one computer to another shouldn't have an affect. The only exception I've seen so far are Fonts. A project file doesn't save fonts, and occassionally you'll see things like titlebocks freak out if an unusual font is opened on a computer with a limited number of default windows fonts.
Is this a workshared project?? Or is it standalone file? If it's workshared, do you possibly have worksets enabled, and, might all of your recent annotations be in a workset?
You plot to pdf first, right? if not, try it and tell us.
Doh. I thought he meant they weren't displaying on the screen. This is a print settings issue, probably vector vs. raster.
This may be a scale issue - but I would need more information. Make the view scale larger and see if it prints.
Export fills to layers |
Fri, Sep 11, 2009 at 11:51:48 PM
EXPORTING TO AUTOCAD- WITH NO COLOR FILLS |
Sat, Mar 31, 2018 at 3:07:57 AM
plotting to a plotting service plotter with a prn file |
Wed, Jun 4, 2008 at 1:14:57 PM
Wishlist - Floor fills |
Fri, Jan 14, 2011 at 5:26:55 PM
Plotting PDF's |
Tue, Jul 21, 2009 at 4:18:06 PM
Members: | 2105954 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
