Xrev Transmit as mentioned in a number of threads is a Sheet/Drawing Issuing tool for Revit that enables you to quickly generate PDF's, DWG's, DGNs, DWF's, DXFs, Hard Copies simultaneously from Revit with preconfigured office standard naming protocols automatically filed into your folder structure in a very quick user friendly 3 to 5 step process. It also uses the Revit information to generate a Document Transmittal in Word and PDF formats.
http://www.xrev.com.au
Our introductory pricing ends in less than 2 days so buy now and save! We guarantee it will pay for itself in just a few uses!
No longer will you have to sit in front of your computer on issue day, Printing PDF's, then Exporting DWG's, manually naming PDF's/DWG's, moving files around, then finally entering all this information manually into your transmittal to finally issue.
If you haven't seen it in action yet, download the free trial today!
If you have any problems, contact our support team and we will assist as soon as possible to ensure you are as productive as possible using Xrev tools.
Cheers,
Chris Price.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
