57 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Timber Mid Rail
6 Posts No Rating |
Hi Guys,
Im using Revit Architecture 2012, does anyone know how to add a timber mid rail onto an existing timber wall, i have already created a profile for this under profiles/skirtings but only seem to load it up when i select the roof/fascia detail, problem is it sends it to the eaves height and not on the level where i have originally wanted it. The midrail is only 25mm x 160mm high which sits on the external wall 750mm up from finished floor level.
Ive attached a cad section illustrating this.
Thanks for your help
Did you tried with "Wall Sweep"?
6 Posts No Rating |
Yes thanks it worked.
Obrigado
Timber panelling 3'-0" high within room Revit 2010 |
Thu, Nov 19, 2009 at 1:55:35 PM
Timber Framing |
Tue, May 9, 2006 at 9:04:39 AM
rail termination |
Tue, Apr 8, 2014 at 10:18:59 AM
Set baluster on Bottom Rail |
Thu, Mar 29, 2012 at 8:59:47 AM
dimensioning to line mid point |
Wed, Aug 27, 2008 at 9:37:51 AM
Members: | 2017243 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
