29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Chamfered edge timber plinth
Mon, Jun 27, 2011 at 5:39:25 AM | Chamfered edge timber plinth
rickzloureiro
Hi Guys,
Im using REVIT ARCHITECTURE 2012 and just cannot figue out how to draw a chamfered timber plinth around my suspended timber floor deck. Do i go into profiles and modify the family or is there another way? I have tried modifying the family but when i import it it is only in 2d and there is no extruded bits. Hopefully im overcomplicating things and there is a simples way of doing it.
I have attached the Plinth detail and the building where i want to connect it to the floor deck.
Thanks for your help
Mon, Jun 27, 2011 at 7:13:20 AM | Chamfered edge timber plinth
4 Stars: 203 Votes
Just create a new profile and use the "Slab Edge" tool
Mon, Jun 27, 2011 at 9:32:44 AM | Chamfered edge timber plinth
rickzloureiro
Muinto obrigado amigo!!!
Funcionou.
It worked, sorry i assumed you were portuguese as the screenshot you used was in Portuguese!!
Mon, Jun 27, 2011 at 9:52:33 AM | Chamfered edge timber plinth
4 Stars: 203 Votes
Sim, sou Português mais própriamente da Guarda.
chamfered beam visibility
Fri, Aug 16, 2013 at 1:02:00 PM
attaching plinth sweep to wall under edit assembly
Fri, Nov 27, 2009 at 7:39:18 AM
Timber Framing
Tue, May 9, 2006 at 9:04:39 AM
timber gable finials
Tue, Jun 26, 2012 at 11:02:02 AM
How would I go about creating a timber frame?
Fri, Feb 10, 2006 at 3:49:50 PM
Page generation time: 0.5143
