Forums >> Revit Building >> Technical Support >> Rotating Topography Fill patten
Can you rotate the topography fill hatch? I want it on a 45 degree angle
http://screencast.com/t/nZijiBdsRVZ
Revit 2018........ |
You can only rotate model hatches.....Is it?
Its not hatch its topography...I suppose I could hide it and do a hatch but even then it won't have an option to rotate the earth hatch like it does for line hatch why is that?
All hatches are hatches. The topography hatch is technically (in the materials manager) "Site - Earth" material's cut pattern. You can't assign a model hatch here, so no, you cannot manually rotate this hatch.
However, you can load in a new hatch, and at that time, specify a 45 degree rotation for it. I can't help you find the location of the .pat files. lots on the net however. Not sure where revit's included hatches are located.
oh there is one in downloads wont download though maybe work pc I will try at home
http://www.revitcity.com/downloads.php?action=search&keywords=earth&user_name=&sort=score
thanks for your help mate.
Edited on: Mon, Jun 27, 2011 at 9:24:43 PM
Can anybody create this dot hatch patten? |
Sun, Jan 5, 2020 at 6:16:23 PM
Dot Hatch/Fill Patten |
Sun, Apr 28, 2019 at 3:54:58 PM
Topography Cut/Fill Schedule |
Thu, Nov 16, 2006 at 11:15:52 AM
Revit Topography schedule - several issues! |
Mon, Jul 14, 2014 at 8:59:01 AM
Topography Schedules and reporting Pad cut/fill. |
Sun, May 7, 2006 at 6:40:00 PM
Members: | 2116431 | Objects: | 23196 | Forum Posts: | 152302 | Job Listings: | 3 |
