Forums >> Revit Systems >> Technical Support >> Keyaboard Shortcuts - Export Yes - Import Fail - Save Fail
Sun, Jun 26, 2011 at 6:10:48 PM | Keyaboard Shortcuts - Export Yes - Import Fail - Save Fail
jodyda
3 Stars: 1 Votes
This is one of those minor annoyances that bothers me every day.  I am hoping it is a simple fix.
Revit Architecture 2011 - I edit my keyboard shortcuts through the internal editor and it works fine during that session.  Once I exit, all of my edits are lost.  Revit is creating the xml file on my drive when I make the changes.  I have checked the xml file outside of Revit to make sure the changes are there...they are.  I tried importing the file in Revit and none of the shortcuts change...tried overwriting and merging both without success.
It is like Revit is not seeing the xml file.  I tried placing the xml file in multiple locations both on our network and different folders on my drive including the default path for user files.
I searched the eight pages of postings on "keyboard shortcuts" with no luck.
Any thoughts?
Plots which fail to plot to scale
Tue, Nov 14, 2006 at 7:50:32 AM
ERROR: could not create integral reveal from wall instance. fail to cut wall.
Mon, Jan 8, 2018 at 8:30:21 AM
export to navis error
Mon, Jun 17, 2019 at 11:21:02 AM
Revit 8.1 import .sat Nurbs, creating curtain wall crashes Revit HARD
Fri, Nov 25, 2005 at 5:14:29 AM
Keyboard Shortcuts Fails to Save or Import
Mon, Jun 27, 2011 at 6:25:50 AM
Page generation time: 10.5504
