55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> see beam on ground level, how can I solve it?
Fri, Jun 24, 2011 at 3:12:38 AM | see beam on ground level, how can I solve it?
shenlunglinnk
3 Stars: 2 Votes
Hi
I make a structural framing family - 2 columns with a beam.
The columns stand on level 1, and the beam is actually 6 meters above the level1' floor.
However, I can see the beam on level 1's plan ...... howcome?
I try to change the referance plane, and even move the whole structure higher inside the family.....but it doesn't work at all.
Do you know how I can solve this problem?
Thank you very much
Mon, Jun 27, 2011 at 7:22:56 PM | see beam on ground level, how can I solve it?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
There are a couple factors.
Since your beams and your columns are all one family, if any edge of the family is visible, it's ALL going to be visible.   What category is your family built in?  And is it built in place, or is it made in a separate family and loaded into your project?
Also, are your view ranges set with a top/cut plane?
Finally, think about making groups.  Instead of a single family that's both beams AND columns, use real beams and columns, get them set up and joined right, and then form a group.  You can then copy and move this group around your project, and won't have the same problems with visibility.
Tue, Jun 28, 2011 at 5:25:07 AM | see beam on ground level, how can I solve it?
shenlunglinnk
3 Stars: 2 Votes
Thank you very much for your reply.
I finally solved it :-)
How to model long ground beam with piles?
Mon, May 16, 2016 at 1:51:15 PM
Creating a under ground level
Tue, Sep 13, 2011 at 12:20:18 PM
Rendering Ground Planes showing up when i dont want them to
Wed, May 10, 2006 at 7:14:44 AM
Existing and proposed ground level
Mon, Aug 4, 2014 at 6:35:49 PM
Toposurface
Fri, Nov 20, 2015 at 11:56:28 AM
Page generation time: 0.8463
