62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> turning section head text
Mon, Nov 21, 2005 at 8:36:33 AM | turning section head text
quiller
quiller Avatar
2.5 Stars: 3 Votes
I have a view that I need to turn 90 degrees to get it to fix on my page. I managed to turn all text notes, wall, window and door tags but I can't seem to figure out how to turn text in section heads. I opened the section head family and dupilacated it and then brought it into the project, but I can't get it to show up in the properties to choose it. I walked through the explation in help, but still can't get it to work......any ideas? Thanks, Alan
Mon, Nov 21, 2005 at 5:03:31 PM | RE: turning section head text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Wouldn't it have been easier to just turn the titleblock? You can also use the rotate command on the crop region to rotate the view on the sheet. Anyways, the section heads are controlled in your settings-->view tags section, you create a new section type and apply the appropriate head to it.
Tue, Nov 22, 2005 at 8:39:24 AM | RE: turning section head text
quiller
quiller Avatar
2.5 Stars: 3 Votes
daaaaaah.......I forgot about the setting..views etc. Correct you are and it works, but it changes the direction of the section head text on all sheets, not just on the one that I wanted to change. Which may be good in some cases, but no good in this case. The issue is we're creating a 1/2" scale plan and I can't fit it on a sheet in the same manner as all the other dwg's which are 1/4" plans. Thanks for trying...........
Tue, Nov 22, 2005 at 9:42:01 AM | RE: turning section head text
Zorch
Just duplicate that view in your project browser, drag it to a sheet and rotate it.
Aligning text a section head
Fri, Mar 2, 2007 at 1:17:12 PM
problem with section head
Sun, Nov 26, 2006 at 4:49:06 PM
custom section head rotation (2019)
Fri, Dec 14, 2018 at 9:28:46 AM
Aligning a label to Section-head
Thu, Oct 20, 2011 at 2:25:01 PM
Reference Labels on Section Heads - MISSING
Tue, Dec 6, 2005 at 5:02:49 PM
Page generation time: 2.9076
