47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> loading library parts and error message
Wed, Jun 22, 2011 at 5:36:24 PM | loading library parts and error message
Warchitect
4 Stars: 5 Votes
Ive just loaded revit 2011, upgrade from 2009,
when I run 2011 the first error message says "default template does not exist" blah blah, to change the default path from the application menu, select options and the the file locations tab.
I can't find this menu option. where is it.
Also: did I do something wrong. should I have new 2011 library folder, or does it use the 2009 library? What happens to all my parts Ive made in 2009? do they get upgraded?
Thu, Jun 23, 2011 at 6:59:55 AM | loading library parts and error message
Your library and template file paths are set using the revit R then the options tab.
Each version has its own library and library maintenance is something you will have to pay attention to.  There is a batch upgrade utility that comes with your program that you can use to upgrade families that you created.  We keep "our" families seperate from the stock library so that we can manage this process and we maintain seperate libraries for each version.
Thu, Jun 23, 2011 at 7:06:13 AM | loading library parts and error message
4 Stars: 203 Votes
Here: the big "R" then "Options"
Thu, Jun 23, 2011 at 10:37:45 AM | loading library parts and error message
Warchitect
4 Stars: 5 Votes
Ohhh, cool hidden button.
thanks for the replies. I realized last night that I should have been keeping my library parts seperate too :-S
Thu, Jun 23, 2011 at 10:45:56 AM | loading library parts and error message
We just put a sub-folder in each category folder for office families.  Then we copy the folder to the new library and upgrade all of its families.
ERROR MESSAGE: STAIRS - rises not intersecting boundries?
Tue, Aug 19, 2008 at 9:12:34 AM
error when loading components
Wed, Dec 1, 2010 at 2:33:55 PM
Loading objects from the Imperial Library
Mon, Jul 14, 2008 at 9:59:56 AM
11
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:49 PM
Error message
Thu, Aug 25, 2005 at 6:21:54 PM
Page generation time: 1.7257
