72 Users Online (70 Members):
Forums >> General Discussion >> Revit Project Management >> Can't select elements like in 2011
3 Posts No Rating |
There seems to be a probleme to select an Highlighted element in 2012. Clicking on the highlighted element will select the one beside. Unchecking the hardware acceleration solve this problem howevere this option will not allow for realistic display and ambiant shadow. Any suggestion?
Thanks
"Clicking on the highlighted element will select the one beside" - wierd, I don't have that problem... did you try the "TAB" key?
"Unchecking the hardware acceleration solve this problem howevere this option will not allow for realistic display and ambiant shadow." - That's true.
3 Posts No Rating |
Even with the TAB, the wanted element gets highlighted but when I click on it it's still another one this is selected. Actually, I realised with the TAB you have to stop your cycle just before your element gets Highlighted, it is just that you have to cycle one or two time to remember what comes before your wanted element! It might be my graphic card.
50 Posts No Rating |
I noticed the same behavior. I have to click several times to select the item I want. I have been keeping the hardware acceleration unchecked because of this.
I think it is the graphics card, which is a bummer since my setup is barely over a year old .
select elements on current level only - revit 2014 |
Tue, Jul 23, 2013 at 7:52:33 AM
I can not select some elements in a file |
Wed, Apr 10, 2013 at 5:28:15 PM
CAN'T SELECT GROUP |
Sun, Nov 25, 2012 at 12:33:43 PM
'unable to copy elements from file' error in inserting a saved view |
Wed, Jul 25, 2012 at 10:16:55 AM
Move elements vertically in Revit Architecture 2011 |
Tue, Aug 3, 2010 at 9:40:17 AM
Members: | 2017179 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
