Forums >> Revit Building >> Technical Support >> How to create a fabric curtain
86 Posts No Rating |
Hey there,
I found and downloaded a curtain someone had made, but it's not editable, so I need to learn how to do it myself. Can anyone give me some tips as to how to create a fabric curtain (like the one in the attachment) - I want it to have the same/similar shape, gathered in the middle and am not sure how to do this....
Any help appreciated!
Thanks
PS Not letting me add an attachment will try again soon....Edited on: Tue, Jun 21, 2011 at 5:24:00 PM
Edited on: Tue, Jun 21, 2011 at 5:24:26 PM
I used the Solid - Blend tool, set a plane where you want the gather to be, create the top section on the gather plane & bottom section at floor level using some spline lines,set material properties & then mirror to get the top half. Add some materials, repeat to create the pelmets if required.
I had only created that curtain just for you CRB14, but funnily enough it has just been required in a project I'm working on - serendipity strikes again!
Multi-Layered Sliding Curtain Wall With Glass + Fabric Curtains |
Mon, Jan 4, 2016 at 9:41:21 AM
Fabric duct |
Wed, Aug 26, 2015 at 1:08:46 PM
question concerning rendering fabric |
Tue, Feb 25, 2014 at 2:01:44 AM
Welded Wire Fabric |
Tue, May 20, 2008 at 11:52:41 AM
Structural Fabric sheet tagging |
Thu, Aug 8, 2013 at 9:57:06 AM
Members: | 2104640 | Objects: | 23178 | Forum Posts: | 152303 | Job Listings: | 3 |
