Forums >> Revit Building >> Technical Support >> How do I create a Barrel Vault Ceiling
3 Posts No Rating |
I was wondering if anyone had any ideas on how to create a barrel vault ceiling?
I have attempting creating a barrel vault ceiling by creating a roof extrusion along the barrel vault path I desire and then editting the type to make it appear as a suspended ceiling system, but then light fixtures and other such items that require a ceiling host cannot be inserted.
Any ideas?
Thanks!
You don't create this as a roof. Create as an in-place family -CEILING category.....
3 Posts No Rating |
haha. i just figured that out after playing a little. Thanks for the help!
1 Posts No Rating |
Hi, could you please explain how did you figure this out?
Where exactly is that in-place family option?
Thanks
You your HELP, it is a good guide. To create on its under Component>Model-In-Place
3 Posts No Rating |
You can create an in place family by selecting "Model in Place." You can find this on the Home tab - Build - Component - Model in Place. Revit will then ask you what type of family category you want to create. In this instance, you can select Ceilings to create a ceiling. Revit will then ask you to name this new family. Your model will then grey out allowing you to create a new family in place. You can do so using the various different forms. I created my ceiling using the sweep command. The best advice, i can give. Just play with it. You will have to create a profile for the sweep to use and a patch for the sweep to follow.
Barrel Vault Ceiling |
Tue, Oct 21, 2008 at 10:12:04 AM
Barrel vault dormer opening |
Thu, Jun 21, 2007 at 2:22:49 PM
Trouble with creating a Ribbed Groin Vault |
Sun, Nov 25, 2012 at 12:04:44 PM
Standing Seam on a barrel vault roof |
Tue, Jul 23, 2013 at 9:06:22 AM
Barrel Vault ceiling problems |
Mon, Nov 22, 2010 at 4:58:04 PM
Members: | 2102364 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
