37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit running slow on my computer
Sun, Nov 20, 2005 at 8:39:03 PM | Revit running slow on my computer
unicorn
Hi, I have an intel P4 3.2ghz, 1 Ghz RAM desktop and finding this is running annoyingly slow... whats the best way to give it speed... our tech. person, (who doesn't know much about Revit) has suggested the following: Dual core CPU RAID hard drives 2.0 gig RAM Anyone have any suggestions?
Sun, Nov 20, 2005 at 8:52:40 PM | RE: Revit running slow on my computer
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
How big is the file you are working on? Your system should handle most files upto 50-60MB fine. Providing you have a half decent video card. Make sure you're not keeping excessive views open. Use the window-->Close hidden windows command to close them occassionally. If your using worksets only open parts of the model that you need to edit/relate to. Make sure you don't have lots of 2D linework in views. As linework is parametric its always looking for relationships. Its actually less impact on a model to draw walls that lines... The RAM is your biggest limiting factor at the moment, for files over 60MB definitely consider 2G RAM. HTH.
Mon, Nov 21, 2005 at 5:49:49 PM | RE: Revit running slow on my computer
vnd
3 Stars: 2 Votes
Mr. Spot, thans for reply, but what would be a decent video card to have?
VND
Mon, Nov 21, 2005 at 5:53:31 PM | RE: Revit running slow on my computer
eldados
eldados Avatar
4.5 Stars: 8 Votes
That's a very sore subject for me at the moment... Sad check out this thread on Augi: http://forums.augi.com/showthread.php?p=226004#post226004 it appears that there is no big difference between a $100 with openGL support and a $1000 with openGL...
Integrator
KarelCAD
Wed, Jan 13, 2010 at 8:26:57 AM | Revit running slow on my computer
EndersChild
I have a frustrating problem similar to yours. I work with revit on two different computers: The ones at my school and the one at home. The school computers are the typical garbage: 1.2 GHz processor, 1/2 gig of ram, no graphics card to speak of. Mine however:
4 Gigs RAM
500 Gigs Hard Drive space
ATI Radeon 1650 PRO
 2 gigs dedicated graphics memory
AMD Athlon(tm) 64 X2 Dual Core Processor 3600+
Someone please tell me: why is REvit running MUCH slower on my computer than on the school's?
Edited on: Wed, Jan 13, 2010 at 8:29:10 AM
Wed, Jan 13, 2010 at 8:49:33 AM | Revit running slow on my computer
4 Stars: 202 Votes
One question, did you turn ON the "OpenGL or Direct3d" in your "Home Revit"?
Edited on: Wed, Jan 13, 2010 at 1:27:58 PM
Wed, Jan 13, 2010 at 4:22:45 PM | Revit running slow on my computer
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I cannot reccomend enabling openGL.  On our computers it was constantly messing with the depth clipping.  I don't know how or why.  panning and zooming for a short time in an elevation view would enable "clipping without line."
Thu, Jan 14, 2010 at 1:13:19 PM | Revit running slow on my computer
demilieu
i'm not able to get revit 2010 to reliably open a family object for viewing or editing. i get kicked out when i try to open a family objet-no matter how small.  i'm seeing the processor is only maxing at 15% when the program locks up.
i'm using a dell inspiron 700m notebook with a 2 gig processor.  2 gb of ram at 1/2 gig speed, 40 gig free hd space, wiindows xp os, and have removed most everything i can from msconfig at startup.  it's an old machine i guess but according to autodesk the program should run ok so long as i keep the files small and don't render.
any suggestions?  the max ram the machine can run is 2 gig.  the only thing i'm seeing is maybe the processor is too slow...but it's later than a pentium 4.
Mon, Jan 25, 2010 at 6:42:56 PM | Revit running slow on my computer
itsmyalterego
4 Stars: 16 Votes
The laptop probably has a crappy onboard videocard.  Laptop sellers always gloss over that rather important component, or neglect to mention it among the features, and throw in some cheap onboard video that struggles with youtube...
If that's not the case and it's decently powerful, you'll want to try updating your drivers, first.  Nothing is released as frequently as graphics drivers, and if the computer is several years old, that software is very obsolete.  Look for the card type under system properties or device manager, or google your laptop make and model.
Revit 2013 Running Slow
Fri, Nov 8, 2013 at 9:19:27 PM
Revit 2013 running slow - anyone have the same issues?
Sat, Mar 1, 2014 at 1:37:57 PM
WHY THE A.REVIT BUILDING GOES SOOO SLOW?
Fri, May 4, 2007 at 2:43:20 AM
Revit Running Super Slow, Powerful Brand New Computer
Thu, Aug 25, 2011 at 8:12:36 PM
revit running slow
Mon, Feb 15, 2010 at 2:40:53 AM
Page generation time: 1.6435
