60 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Perforated metal panel
9 Posts No Rating |
hello all
I am trying to model a perforated metal panel for a building that I am currently designing. I am fully aware that I can show the perforations through the rendered material, however I need to physically model it so that it can be seen in the non rendered elevations....does anyone have some tips on how to do this?
Thanks
Why would you need to model it? Perforated panels are usually represented by a surface pattern in non-rendered views.
1 Posts No Rating |
One reason you might want to model it is to be able to specify it with Keynoting and have it cross reference your Specifications.
this may be slow and somewhat heavy geometry, but have you thought of editing the wall profile? using the array function may speed things up. The best and most accurate method would be to create a family that can then be scheduled/tagged etc later...
jawycoff, As a material, it can be keynoted and cross-referenced to specifications - still no need to model the holes. And the question was about non-rendered views. An associated model hatch for the material will do that.
perforated metal or Expanded sheet metal [ 1 2 ] |
Mon, Mar 5, 2018 at 5:55:54 PM
25
Perforated Metal Panels |
Mon, Apr 26, 2010 at 11:46:49 AM
Perforated Metal Panel-Fill Patterns |
Thu, Sep 14, 2006 at 10:14:35 AM
Perforated Panel and Modeling |
Tue, Jun 7, 2011 at 9:47:53 PM
Perforated metal screen? |
Fri, Nov 12, 2010 at 9:21:25 AM
Members: | 2042225 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
