42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Demolished walls hiding proposed stuff
Mon, Jun 20, 2011 at 7:12:02 AM | Demolished walls hiding proposed stuff
fabioloretti
3 Stars: 2 Votes
Hi guys, I've been trying to fix this problem with no success at all. No idea what I should do by now...
Check the picture so you can understand what I'm talking about. You can see two red arrows pointing at the problem. My walls and doors to be demolished are hiding the proposed objects and even the proposed walls. I tried overriding the demolish by going at the phases dialog but it didn't work. Would you be able to help me on this?
Any help is appreciated.
Mon, Jun 20, 2011 at 7:30:36 AM | Demolished walls hiding proposed stuff
3.5 Stars: 395 Votes
Phases will work so try again.  Maybe come back with your view settings and your phase settings.
Mon, Jun 20, 2011 at 8:02:35 AM | Demolished walls hiding proposed stuff
fabioloretti
3 Stars: 2 Votes
There you go.   :-)
Thanks, WWHub.
Mon, Jun 20, 2011 at 8:42:46 AM | Demolished walls hiding proposed stuff
So you have set your view to the appropriate phase?
Mon, Jun 20, 2011 at 6:04:55 PM | Demolished walls hiding proposed stuff
fabioloretti
3 Stars: 2 Votes
I did. Phase Filter "Complete + Demolish"...
Tue, Jun 21, 2011 at 6:55:42 AM | Demolished walls hiding proposed stuff
So you are showing the items to be demolished.... therefore, they will be there!  If you don't want them to show or if you do want them to show but don't want them to hide elements, then that is up to you in your settings.
Tue, Jun 21, 2011 at 8:36:01 AM | Demolished walls hiding proposed stuff
fabioloretti
3 Stars: 2 Votes
I actually want them to be shown. But what I can't figure out is how have them clear in the middle. Transparent, showing only their outlines so they don't hide the other elements. Is that possible?
Tue, Sep 20, 2016 at 12:49:01 PM | Demolished walls hiding proposed stuff
lisahenning
This is a huge issue for my firm! has anyone solved it? We make proposals that show demo and new but demo hides the new
Tue, Sep 20, 2016 at 1:35:36 PM | Demolished walls hiding proposed stuff
Read this similar thread that is listed in the similar threads below:  Always check those for an answer.
Tue, Sep 20, 2016 at 5:54:34 PM | Demolished walls hiding proposed stuff
fabioloretti
3 Stars: 2 Votes
Hi everyone, I couldn't find a proper way to do it but I came up with a workaround which is not exactly amazing but does the job.
1. Duplicate all the wall types to be demolished and add a DEMO at the beginning of the wall type name;
2. Create a filter that picks up all the wall types containing DEMO in the name;
3. Add the filter to the views (or view templates) and set the transparency to 100%.
Done.
Schedule or quantity for just demolished walls
Wed, Sep 19, 2012 at 1:16:22 PM
Turning off demolished walls
Tue, Apr 11, 2006 at 7:55:05 PM
Existing door reused in proposoed phase
Tue, Oct 14, 2014 at 8:06:54 AM
Existing and Proposed Problems
Tue, Jan 28, 2014 at 7:56:04 AM
MAKING DEMOLISHED OBJECTS TRANSPARENT
Tue, Mar 12, 2013 at 2:02:34 PM
Page generation time: 6.0225
