Forums >> Revit Building >> Technical Support >> How do i put a ceiling fan on the ceiling?
3 Posts No Rating |
As the topic describes i am trying to put a ceiling fan on the ceiling but when i select the ceiling fan component it shows the circle with the line crossed on it... meaning it wont let me put it there.... thanks.
That's because that family was not created to attach to a ceiling, that's why you have that "Circle with the line crossed on it..."
3 Posts No Rating |
ahh ok thanks, so is there anyway to attach the fan to the ceiling or is their another method?
Create a new family, in this case a "Generic model ceiling based" then Copy/past from the "Original" family to the new family and attach that object to the ceiling with the "Align" tool, if that family is a parametric family you will loose some parameters but....
what CAN your ceiling fan attach to? You also might check the library for a "face based" ceiling fan. Be sure to read the details of what you grab.
3 Posts No Rating |
ok thanks =) and just one last nubbie question.. when i render an image of inside my room i cant get the room to be fully lit so i can see everything within it.I have tried different schemes but i just cant seem to get the image of the room fully lit up? I have included a picture to demonstrate please help thanks.
You need to turn ON the "Daylight portal", search in your HELP menu for that
2 Posts No Rating |
Yes, with all the ceiling fans for download, I wonder why they werent made to attach to a ceiling!?
I too can not make a ceiling fan work, only get a circle with a line through it.
Thanks
Nothing has changed here.... If you are using a ceiling hosted family and you are working in a reflected ceiling plan, then you will not get that symbol.
I am a 5-year Revit user. OK, no genius. I downloaded the ceiling fan. It is hosted to a ceiling family. It will only let me see it on a floor view when I go to place it. After I place it, I can't see it, using all that I have learned in 5 years. I do what an intermediate user can do. Can't see the fan. So this is not a kiddie issue. Sure, there is probably something obvious I am missing. But with Revit, that is like saying I will need to breath within the next minute. Just a post of encouragement. Thanks for all who have shared.
