102 Users Online (101 Members):
Forums >> Revit Building >> Technical Support >> Curtain Panel Surface Pattern not showing in 3D View when set to Hidden Line
2 Posts No Rating |
A curtain panel surface pattern shows up in all my working views (axons, etc.), however it is not showing up in my 3D camera views. All the visibility and material setting are correct. I know because the surface pattern shows up when I set the view to Constant Colors, but I need the view to be Hidden Line and the pattern goes away.
Any thoughts on how to fix this or get around it? I also tried overriding the surface pattern of curtain panels in the view and that did not work either.
your hatch color isn't white, by any chance?
2 Posts No Rating |
@ itsmyalterego
Nope, the surface pattern is a solid blue color with a 25% transparency.
I don't know.
I'm looking at a 3D camera view right here though, in hidden-line, with solid surface hatches turned on, and curtain panels in particular, hatched. Adding 25% transparency to my material works perfectly with the solid surface pattern. To be clear-- I'm adding a hatch to the -material- the panel is made of, not to the curtain panel category.
Try making a new camera view, and/or apply a view template you've made from an existing view that looks like you want. Sometimes some views get a little... funny. Is this not isolated to one 3D view, though?
pic attached, correct me if I'm wrong--this is similar to the effects you're looking for?
Edited on: Fri, Jun 17, 2011 at 3:22:37 PM
Parametric Curtain wall panel in divided surface |
Sun, Jan 31, 2010 at 8:08:54 AM
Cut Pattern for Curtain Panel Not Showing in Plan |
Fri, Sep 5, 2014 at 6:25:57 PM
Surface pattern on pad only shows up when it is highlighted. |
Mon, Nov 26, 2012 at 10:59:11 AM
Surface orientation in panel by pattern |
Thu, Apr 24, 2014 at 6:02:34 AM
Surface pattern and Render Appearance Do Not Match |
Tue, May 7, 2013 at 11:44:06 AM
Members: | 2057914 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
