60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering - Brick looks like a stone pattern
Thu, Jun 16, 2011 at 4:00:59 PM | Rendering - Brick looks like a stone pattern
mcrowe
When I render my model my brick looks like it has a stone pattern.  The hatch pattern selected is the generic brick.  Please help!  Any other tips would be greatly appreciated....this is my first time working with revit.  Please note that the screened porch and a few other various issues have been cleared up since this rendering.
Thu, Jun 16, 2011 at 4:04:16 PM | Rendering - Brick looks like a stone pattern
mcrowe
I am also trying to figure out why the brick color looks so light?
Thu, Jun 16, 2011 at 4:32:19 PM | Rendering - Brick looks like a stone pattern
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
the render apearance has little to do with the hatch pattern -- except it's orientation.
When you go to the material manager, there is a tab for each material called "render apearance" and you have a library full of jpgs that you can assign to different materials.  In most cases, this has to be done manually.  You can scale these render materials, give them bump patterns, and more.
But again, in most cases, you have to manually tell revit what render material goes with a material.  Many are just default gray, and it looks like your brick material is masonry, rock, or some other incorrect material.
There are lots of similar threads about managing render materials.  See below!
Fri, Jun 17, 2011 at 12:48:59 PM | Rendering - Brick looks like a stone pattern
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Looks like your rendering at a very low density setting. Needs higher density to get a good look. May take awhile to render properly.
Wall Clading- Shaded stone/ Brick
Mon, Aug 24, 2009 at 7:05:03 PM
acme brick patterns
Wed, Feb 8, 2006 at 11:35:37 AM
brick pattern not consistent
Wed, Mar 16, 2011 at 1:22:14 PM
Stone Pattern RAC V2009
Fri, Apr 25, 2008 at 10:30:15 AM
Stone Wall
Tue, Aug 20, 2013 at 3:55:33 PM
Page generation time: 0.6929
