110 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Parent views & Dependent view dimensoins
Thu, Jun 16, 2011 at 3:41:13 PM | Parent views & Dependent view dimensoins
gregroberson
gregroberson Avatar
I would like to work in the parent view of a building plan that has six areas.  As I dimension, I must constantly start and stop dimension strings.  Can Revit RST2011 just juncate dimensoins not fully enclosed on the sheet or does the whole string have to be included?
I hope that was clear enough.
Greg
Thu, Jun 16, 2011 at 4:44:38 PM | Parent views & Dependent view dimensoins
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I think I know what you mean -- dimension strings not fully enclosed on a sheet.   This should be manageable by crop, and annotation crop regions per dependent view, I think.
Thu, Jun 16, 2011 at 4:50:29 PM | Parent views & Dependent view dimensoins
gregroberson
gregroberson Avatar
Great, I'll check that out!
Dependent views not the same as Parent view...
Fri, Jun 16, 2017 at 11:02:18 AM
Detail Callout Bubbles and Dependent Views
Thu, Aug 12, 2010 at 6:51:10 AM
View Reference tags in parent view disappear when viewing the parent sheet
Fri, Nov 6, 2009 at 3:32:26 PM
Different Scales Using Dependent Views
Sun, May 20, 2007 at 6:41:56 AM
Dependent Views - My dimensions stink
Tue, Aug 24, 2010 at 12:49:03 PM
Page generation time: 7.5624
