96 Users Online (94 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how to view a toposurface with thickness in a elevation ou in a 3d view??
Thu, Jun 16, 2011 at 10:34:57 AM | how to view a toposurface with thickness in a elevation ou in a 3d view??
querosaber
in 3d view and elevations , the site toposurface apears omly "surface" Smile !!!!!.
how have a site witk tickness , like showing  a block of terranin?
and not only a sheet of terrain..
thanks a lot
Thu, Jun 16, 2011 at 10:56:11 AM | how to view a toposurface with thickness in a elevation ou in a 3d view??
3.5 Stars: 396 Votes
For 3D views, if you use a section box and if the section box cuts the topography, it will then have thickness.
Thu, Jun 16, 2011 at 11:06:23 AM | how to view a toposurface with thickness in a elevation ou in a 3d view??
querosaber
thanks a lot . fantactic!
can put some layes on toposurface similar to floors ?
Thu, Jun 16, 2011 at 11:08:30 AM | how to view a toposurface with thickness in a elevation ou in a 3d view??
You can split a topo face and assign different materials like grass / water / earth / asphalt.....
Thu, Jun 16, 2011 at 1:07:26 PM | how to view a toposurface with thickness in a elevation ou in a 3d view??
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
You can also draw subregions.  subregions allow you to draw regions that you can select and give different materials to.  The upside for subregions is that it doesn't make separate toposurfaces, and changes to your topo won't leave gaps and holes.
Thu, Jun 16, 2011 at 1:13:39 PM | how to view a toposurface with thickness in a elevation ou in a 3d view??
querosaber
I thinked about layers horizontaly...
Thu, Jun 16, 2011 at 1:28:29 PM | how to view a toposurface with thickness in a elevation ou in a 3d view??
itsmyalterego
4 Stars: 16 Votes
No, not really.  Revit hatches in earth below toposurfaces, down infinitely.
Often in a section it's easier to draw your cut topo as a filled region rather than fuss with the actual topography.
Toposurface thickness?
Tue, Jan 24, 2012 at 9:55:03 AM
Large Toposurface and File Size
Fri, Aug 29, 2008 at 10:15:18 AM
Thickness for toposurface
Wed, Jan 3, 2007 at 11:47:22 AM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Page generation time: 1.4901
