Forums >> Revit Structure >> Technical Support >> Execute Journal File through Batch File
Looking for the code to run a journal file through a batch file.
I would like it to do the following.
1. Execute Revit with Journal file(directory location)
2. Delete Journal Files
3. Exit Batch
I can't find much help on the web. Surely, someone here knows how to do this.
thanks you in advance.
Really, I just need to know how to execute Revit with a journal file.
drag the jounal file and drop it on top of your Revit Desktop icon is one way
Drag and Drop is the behavior I am trying to mimic with the batch file.
I have used this in the past at an A+E firm where the Architects were using AutoCAD and the Engineers were using Revit. Using a batch file was our way of keeping .dwg drawings current. Essentially we created a journal file which opened the central file detached, exported pre-selected views to autocad, and closed the program.
We then executed the journal file with a batch file. The batch file ran the journal file, deleted any newly created journal files, and shut the computer down when it was done.
I need to know how to EXECUTE A JOURNAL FILE WITHIN A BATCH FILE.
Execute Journal File through Batch File |
Thu, Jun 16, 2011 at 2:33:15 AM
Revit 2012 - Try to recover rvt file from Journal Files |
Mon, Jun 25, 2012 at 12:16:28 PM
ARGHHHHH....lost file. Found journal txt file though |
Mon, May 5, 2008 at 7:07:47 PM
Revit Family Batch Updater - Anything like this? |
Wed, May 12, 2010 at 6:03:47 PM
Massive file slow down |
Fri, May 2, 2014 at 3:03:25 PM
Members: | 2098956 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
