Forums >> Revit Building >> Technical Support >> Help, Title block scale appear to be wrong and can not be changed
8 Posts No Rating |
This very odd thing happened to one of my project file.
No matter the viewports in the sheet is 1:100, 1:200, 1:500, the title block always read them as 1:50.
but if the viewports are not same scale, the title block can read as "as indicated".
We use the standard title block for all projects and the other project never have this problem.
How is this happenning? Is it a secret setting error in the file?
Any help will be appriciated!
8 Posts No Rating |
Update info
I just found out the "screwed" part is my wall type legend, if that is deleted from the sheet, the title block can read the sacle right.
And it is the wall type legend that no matter how I change its scale, the title bar on its bottom always and always and always appear to be 1:50
8 Posts No Rating |
Problem solved~!
maybe no one is reading this, but it may help others when they face the same problem.
The reason caused the problem was the wall type legend scale on the left bottom of its view was not matching the viewport scale, they should be linked and somehow in this file they manage to unlink the scale, once I change the wrong scale on the left bottom to match the viewport scale, they are linked again, and now change with each other accordingly.
I don't think this is a setting problem, it may just be a program fault. When revit stop making sence, it can stop making any sence
0 Posts No Rating |
Can you please guide me through this? Maybe you tought only you had this problem but no...
As a difference of you I do not have any wall legend
Also on the title block even if I change the scale, the title keeps the same scale.
Apreciated if yo could help.
Thank you
Edited on: Fri, Aug 26, 2016 at 3:43:14 PM
View title scales, if not just text, will always read the view scale. iRevit also allows you to have a parameter in your titleblock to read the view scales on a sheet. BUT - IT READS THEM ALL! If they are all the same, then this parameter will work correctly. If they are not the same, then this is when you will have problems.
Typically when the views are not the same, then this titleblock will read "As indicated". But in the Revit version when this was posted, the view scale of a legend messed up the process. A programming error. I don't know if that has been fixed in later versions because we would never use this feature.
We only show the scale within the view title because we think this is a better process.
0 Posts No Rating |
Is not text. My floor is set to scale 1:200, when I go to my sheets which includes the title block I click on the main floor plan (where I have the problem) and I click on it. Properties in the sheet: Main floor plan show a scale of 1:125 and I want 1:200. and this is why it shows on the title. but I cannot modify it since is in gray non editable.
0 Posts No Rating |
All my floor plans are set to 1:200
You do not say - is this the only view on the sheet?
Some things you sayt are confusing. You write "...when I go to my sheets which includes the title block.." hugh? I your titleblock sepereate from the sheet? The titleblock should be part of the sheet family, nhot something added to a sheet.
0 Posts No Rating |
Please see attched pic, and I as was saying the scale I cannot modify it. The floor plan is set to 1:200 but idk why is still saying is 1:125
Title Block Issue |
Tue, Feb 16, 2016 at 3:52:27 PM
View Title drawing scale associated to the right and moving with the line |
Wed, May 9, 2018 at 5:41:08 PM
Font on Title sheet absent from project Title Block |
Thu, Sep 15, 2022 at 12:31:26 PM
Title Block Fun! |
Thu, Jan 5, 2012 at 6:34:19 PM
Importing AutoCAD Title Block Line Thickness Problem |
Wed, Feb 20, 2013 at 1:40:15 PM
Members: | 2030694 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
