102 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Interior elevation - walls next to each other are showing where they meet
Fri, Jun 10, 2011 at 12:27:39 PM | Interior elevation - walls next to each other are showing where they meet
Maring
Revit 2011.  I have an interior elevation where two different wall types butt up against each other.  There is gyp. bd. on both wall types as the interior finish, yet I still see the line where the two walls meet.  Is it possible to get rid of this line?  Thanks.
Fri, Jun 10, 2011 at 12:38:16 PM | Interior elevation - walls next to each other are showing where they meet
Use your join tool.  If that doesn't work (but it will if they are the same material), you can always use the linework tool.
Tue, Jun 21, 2011 at 12:26:23 PM | Interior elevation - walls next to each other are showing where they meet
shiva1507
Hey WEEHub, your Answer seems perfect, because i use the same trick, (Use join tool and make sure the material is the same,if not or if it cant be use the lineowk tool and make the Invisible line)
However i believe there must be some other way of doing this as we always know there will be column inbetween walls and the wall material (Brick) and column Material (Concrete cant be thes same )  and in a project we would come across 100s of instance where wall meets column,
so i believe thery must be another easy way of doing this other than line work.. (invisible line)
Interior Elevation linewieghts
Wed, Aug 19, 2009 at 2:02:43 PM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
Wall and interior elevation visibility graphics settings.... [ 1 2 ]
Thu, Aug 2, 2007 at 9:29:35 AM
15
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View
Tue, Jul 22, 2008 at 9:38:24 AM
Interior Elevation Tags in Detail Plan Views
Tue, Nov 9, 2010 at 8:06:17 AM
Page generation time: 0.8714
