59 Users Online (58 Members):
Forums >> Revit Systems >> Technical Support >> View Range Issues
I am having some issues with my view range in one of my ceiling plans at the moment.
I have the view cut set to 2400 from the floor level, however it is not showing up some of my walls which have openings of 2400.
I cannot make the view cut any lower or some of the external 3D roofs begin to show in the view and distort the walls which are attached to them.
Is there maybe a way I am able to create multiple cut planes so that I am able to see both the 2100 and 2400 openings in the plan view?
Any information or help would be appreciated.
18 Posts No Rating |
raja15,
If it's only for visual purpose, duplicate the plan view, set the cut plane offset to desirable height (i.e. = 2400mm) then hide the roof in that plan view.
Hope it helps.
Plan regions might work for you here. With a region, you can set different VP ranges from the main view. You can read about these in your help.
view range issues |
Tue, Nov 18, 2008 at 5:06:43 PM
Revit MEP 2012-View Range |
Fri, Apr 12, 2013 at 7:22:48 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
Revit 2009 help with shaft view issues |
Fri, Oct 24, 2008 at 10:41:16 AM
Plan cuts incorrectly at windows despite correct view range |
Thu, Aug 6, 2009 at 9:12:23 PM
Members: | 2042257 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
