65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> exporting avi
Fri, Nov 18, 2005 at 9:58:01 AM | exporting avi
friday
im having trouble exporting my walkthrough as an avi. ive done everything, settup up everything just right and have played it back. its perfect. now i just want to save it. but when i go to file, export, avi.... nothing happens. the save option box doesnt appear? and i dont know why? help will be deeply appreciated as i have an animation due soon!
Fri, Nov 18, 2005 at 11:57:43 AM | RE: exporting avi
orv
4.5 Stars: 7 Votes
with me it works fine ,so i don�t understand that , but if you post a screen shot i think i will be good! witch type of walkthough do you want to do?Acu_render,shading with edges?
Fri, Nov 18, 2005 at 4:53:44 PM | RE: exporting avi
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Make sure you are viewing the actual walkthrough screen when you export... It should come up with a dialog to specify the compression type etc and then save location.
Fri, Nov 18, 2005 at 7:46:10 PM | RE:
friday
i need an accurender shaded walkthough. ive been taught how to do a walkthrough and have seen someone do it. but for some reaosn i cant export it. when i try to i am at a walkthough view.. and ive deleted all the other mock up walkthroughs aswell.. so theres only one.. when i played around with the exporting i tried to export it as a dwg and the save as options box appears... but its doesnt appear for the avi selection... could it be my file is to big or something? or do u have to specify somewhere that you have finished your walkthrough path and camera angles before its accepted like when u gottta finish sketch or finish family?
Sat, Nov 19, 2005 at 1:12:50 PM | RE: exporting avi
winn
hi . can someone tell me how to change the height of the camera while doing a walkthrough?
Sun, Nov 20, 2005 at 7:20:30 AM | RE:
friday
you creat a section where ur path will be visible, view the section, then right click on ur walkthought and select show camera, then edit ur path.. i think ive figure out the problem i had earlier... im not exactly sure though, but i think when i was muckin around with the walthrough to get familiar with the process i started saving a mock version and that inhibited me from saving another one under the same name... its working now, i deleted the mock one.
exporting walkthrough to avi
Wed, Apr 25, 2007 at 5:20:45 AM
convert avi file to wmv or similar file
Thu, May 1, 2008 at 11:06:42 AM
exporting a walkthrough in r08
Thu, May 29, 2008 at 9:03:59 AM
Walkthrough gets 2 major problems when exporting
Mon, Apr 22, 2013 at 11:32:22 AM
Lighting a Exported Rendered Walkthrough
Thu, Sep 10, 2009 at 2:00:55 PM
Page generation time: 5.2722
