41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to create a curved sweep?
Thu, Jun 9, 2011 at 12:37:03 AM | How to create a curved sweep?
CRB14
Hey, I can't for the life of me figure out how to create a curved sweep - see image attached. I need to sweep the profile seen in the image (1/4 circle) around the front edge of the arch......help??
Thu, Jun 9, 2011 at 2:04:53 AM | How to create a curved sweep?
ronWu
ronWu Avatar
You can select the corners of a mass to model a sweep.
So make a mass that has your shape in it and then make a sweep with pick path.
Thu, Jun 9, 2011 at 11:21:09 AM | How to create a curved sweep?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
No image, however create a work plane and name it at or near your arch. If you name the work plane you can use the framing view and it will snap to the work plane. Also draw a section perpendicular to the work plane you will need this later to draw the profile of the detail for the arch. Then in the view normal to the work plane Home, Component, Model in Place select sweep. Create the path of the sweep. Following your arch. Then finish the path but not the sweep, go to the section you created earlier draw profile, and finish sweep. Note that the section will need to be looking at the halfway point of the path.
Thu, Jun 9, 2011 at 1:40:36 PM | How to create a curved sweep?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Hey there.  For sweeps, you can "pick path" instead of drawing a path.  Any 3D edge will work.  It's very, very simple, and looks great.
pic attached, and related.
Curved sweep?
Thu, Mar 11, 2010 at 9:22:28 PM
Curved roof with sweep?
Fri, Jan 9, 2009 at 5:26:10 PM
Revit 2015, Curved Wall Sweep Model Surface Pattern Inconsistant
Tue, Apr 28, 2015 at 4:09:13 PM
How to do a vertical reveal in a sweep in a curved wall?
Thu, Oct 22, 2009 at 2:04:26 PM
multiple curved/ arc and straight joined path line issues
Wed, Feb 14, 2007 at 6:32:43 PM
Page generation time: 0.9161
