Forums >> Revit Building >> Technical Support >> Total Noob making the switch from ACAD
2 Posts No Rating |
Hello!
Alright first time really trying to learn revit, I am using 2012 and so far I am not getting very far. Why every new program uses this stupid "ribbon" thing I dont know but maybe thats just me.
As for my question, where in the world can I use construction lines? I understand there are reference planes and I am still learning how to use them but what about old school construction lines (that don't show up in anything but just help me draw)? I know this is elementary but I can't for the life of me figure it out, can't find it on the web / help / autodesk forums (ive spent an hour on this GRRR). Anyways thanks in advance.
I use a combination of ref planes and details lines (that I later erase) as construction lines.
Just one more area where Revit requires different methods and ways of thinking about how to go about things.
some people use the reference planes or reference lines as a replacement for construction lines. is there anything about these that prevents you from using them as you used construction lines.
hth
In most cases, there is no reason to use "construction lines". Just add the element. This is one of the big thinking changes you need to make.
2 Posts No Rating |
Thank you for the responses. I think I discovered the source of my problem but no solution yet, the reference lines / planes icon is not listed under the datum panel for some reason so I literally don't have it! I'm guessing this is going to become a reinstall issue?
Is there a short cut to use the reference line command, and for that matter how about a list of keyboard short cuts, I think thats my next stop.
EDIT** I found a link to a list of short cuts which solved my problem and is helpful, it is a 1 page list of short cuts with a second page of useful little tips - great for me and hopefully another "noob" will find it useful as well.
http://davidddriver.com/Product/Freebies/Revit/Revit%20keyboard%20ShortcutsVert.pdf
However I still don't see the "reference line" command / icon under my datum panel. Could someone confirm whether or not that is or is not supposed to be there in Revit 2012? Maybe there is a way to edit which commands appear in the panels? Thanks
Edited on: Thu, Jun 9, 2011 at 10:34:02 AM
Edited on: Thu, Jun 9, 2011 at 6:47:26 PM
WW, is correct once you get the hang of this program you will need the construction lines feature less. I use the annotation lines it's green and you can hide them as a catagory or as an element by selecting one right clicking and hide in view, then click the light bulb at the bottom ribbon if you need them again.
Get familiar with the "align" tool. AL is the hotkey. that thing kicks curse. Also, you can use detail lines, though I find that's a rare need.
Also, you can change distances with the automatic dimensions that pop up with any object you select. just drag the blue grips of those temp dimensions to other objects you want them to reference.
Anyway, it's a frustrating transition of course, but Revit provides all the tools for easy, fast work. Nobody in my office regrets the switch even remotely, after several months of them training up.
Jubay, if your problem are the snaps, you can , as example, start drawing a wall, and to select the type of snap, just hit the TAB button.
Also i use the grids as guides... not too many, just the structural ones. Hope it helps a lil
My 2 cents on the top of what other said is to use shortkey as much as I can (since you are the long time cad user, you will find it very efficient to use shortkey, just keep it in mind that don't hit spacebar or enter key to execute your command as this is one of the old habits many faced)
Also, check it out the customizable shortkey under View-->user interface --> keyboard shortcut.
This is where you can customize your shortkey command (say align --> AA, it beats AL) and you can customize to mimic most of the cad command to your need.
To answer your question on reference line, it is not avaliable in the project environment since it is mainly use it in the family editor mode (a different interface than project), so don't bother looking for the buttom.
use reference plane or detail line in the project should get yourself familiar at the beginning.
"Why every new program uses this stupid "ribbon" thing"
you don't have to use the ribbon with revit- in fact i know of no other modern professional software program that has a ribbon.. revit made a turning point in its history with release 2012- and for the first time in ten years- revit no longer has the high performance conventional UI.. and depending on who you work for- you may never need or want to use release 2012 or higher.. there comes a point in the life cycle of any software program where it reaches full maturity and has maximum stability and performance.. that is exactly what release 2011 with update 2 represents- and it has the conventional UI.. i have many seats of revit at my residential design firm and we will be using revit 2011 until a new upstart virtual construction program becomes available..
I can't assign a switch ID to a switch |
Wed, Dec 9, 2020 at 5:42:47 PM
SF Inquiry tool like in Acad?? |
Wed, Jul 23, 2008 at 8:40:48 AM
Importing ACAD Drawings - Experiences? |
Fri, Aug 6, 2004 at 8:54:58 PM
Switch ID Grayed out in Revit MEP |
Tue, Feb 26, 2013 at 11:33:37 AM
Inquiry tools Like Acad?? |
Thu, Jul 24, 2008 at 1:26:30 PM
Members: | 2098225 | Objects: | 23168 | Forum Posts: | 152291 | Job Listings: | 3 |
