54 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Turn off Gridlines in interior elevations
9 Posts No Rating |
Revit 2011. Is there an easy way to turn off all gridlines that show up in my interior elevations? I know I can open each elevation and turn off the gridline category, but I have 200 rooms to do that to! Thanks!
![itsmyalterego Avatar](user_avatar/109615.jpg)
The key to solving your busy-work problem is "view templates."
If you get the settings you like for one elevation, you can save those VG settings as a view template, and apply them to other views. If your project browser is sorted normally, you can select all your interior elevations, and apply a template in bulk. as in, shift-click select all interior views, right click, apply view template.
If you've sorted your browser by "hide views on sheets" you might have to disable that type of sorting for a minute. minor inconvenience.
Edited on: Wed, Jun 8, 2011 at 8:35:08 PM
9 Posts No Rating |
Thanks!!
dimensioning gridlines |
Sat, Nov 4, 2006 at 10:27:59 AM
Problem with Interior elevations |
Fri, Feb 13, 2015 at 1:51:29 PM
interior elevations |
Wed, Apr 11, 2007 at 9:43:04 AM
Revit architecture gridlines |
Mon, Dec 7, 2015 at 7:20:47 AM
Turning off Interior elevations on Site plan, but keep Exterior on? |
Fri, Oct 19, 2007 at 12:38:04 PM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
