33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Some levels blue, some black
Tue, Jun 7, 2011 at 9:26:24 AM | Some levels blue, some black
DaveLowery
In RST 2011 (and others I'm sure) when I cut a section, some of the level symbols are blue but most are black.
What up?
Tue, Jun 7, 2011 at 9:40:02 AM | Some levels blue, some black
Black means that you do not yet have an associated floor plan with that level.
Thu, Jun 16, 2011 at 1:12:26 AM | Some levels blue, some black
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
DaveLower, when you copy on an elevation or a section the level symbol, you just copy the symbol, not creating new levels. To create levels from those symbols, go to view/plan view/floor plan and select them all (hit OK). Same for reflected ceiling plans.
Thu, Jun 16, 2011 at 7:08:05 AM | Some levels blue, some black
Nasty, as a correction the item you refer to is a level.  (The level head is only a sysmbol but the level is represented by a line.)   A copied level just does not have any associated plans.  Levels are almost like reference planes except they have some special characteristics.  You can create levels by copy in elevation and section or from the datum tab.
All allout tags all blue....nothing blue in Visibility graphics
Wed, Oct 2, 2013 at 9:03:15 AM
Blue Line - Visibility/Graphics Issues in Floor Plan
Tue, Nov 6, 2018 at 7:56:57 AM
Levels array
Wed, Feb 20, 2008 at 9:08:59 AM
Black or Blue dots in linked Structure file
Sun, Oct 29, 2006 at 8:00:27 PM
BLUE SECTION CUT SYMBOLS
Thu, Aug 5, 2010 at 12:51:29 PM
Page generation time: 0.5257
