46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> How to make a curved timber batten wall?
1 Posts No Rating |
Hey im currently using revit architecture 2011 and im pretty new at this so i was wondering if anyone had any ideas on how to construct a curved timber wall...I am trying to create a realistic timber wall with steel framing and a spacing of 10mm between the timber battens. I have tried to use the radial array tool but that only managed to create a batten over a batten facing in another direction. The closest I've got to this has been through the railing tool where i have just changed the height to a wall height and created a new post to represent a timber batten as the dimensions of the given posts cant be changed however with the created posts the material cant be altered.... help!
if you are a subscription member, you can download the extension (although I don't think it's that great.)
you can also try modeling it as a curtain wall. This will give you more control.
Colorbond wall_section structure...HELP!! |
Sun, Aug 5, 2007 at 11:30:19 PM
Batten Insulation - System Wall - Section |
Thu, Feb 16, 2012 at 1:10:29 PM
Board and Batten wall |
Thu, Jul 14, 2016 at 3:11:00 PM
timber curtain glazed wall |
Thu, Feb 23, 2006 at 2:56:15 PM
Array formula (9.1) |
Mon, Sep 24, 2007 at 7:12:47 PM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
