47 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Storefront schedule: wall length changes
I have a storefront wall and schedules for cd's. The schedule parameter for wall length changes when a wall is placed perpindicular to the storefront,and I can visibly see the little blue dot grip point jumping into the middle of the adjacent wall and changing the schedule parameter for wall length. I have tried join options, and disallow join, but nothing is getting my schedule, plan, and elevation all reading the same.Any help would be appriciated, thanks. See attached
http://www.turbosquid.com/Search/Artists/Revitaoist |
Sorry - I did not open your project.
Is the storefront full height or is it embedded in another wall? If it is embedded, then your perpindicular wall could be joining the "host" wall above/below the CW.
Just turning off the join button may not be what you want. You may be wanting to drag the blue dot back to the face of the CW ... or wherever you think this wall should end.
It is not embedded into another wall. Dragging the blue dot grip point back to where it should be does nothing, the grip jumps back to the center of the adjacent wall. Check out my attachment for a simplified version of the issue. Delete the perpendicular wall, then switch windows to the wall schedule and ctrl+z, ctrl+y to see what is happening.
If the wall "jumps back", then you did not turn off the join function for that end of the wall. Right click on the blue dot and pick "Disallow join".
That does it, I was not aware of the right click option, Thanks. You know more than subscription tech support!
window / storefront schedule, |
Thu, Sep 10, 2009 at 1:02:39 PM
Storefront Wall needs Storefront Doors |
Mon, Dec 3, 2007 at 8:58:52 AM
How do I create a wall schedule that also calculates total length of walls? |
Wed, Jul 25, 2012 at 6:28:16 PM
Storefront Window Panel Dynamic Length? |
Fri, Jun 30, 2006 at 1:43:15 PM
wall schedule showing zero length for demo infill walls |
Tue, May 11, 2010 at 1:37:18 PM
Members: | 2056516 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
