24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> "Sheet Issue Date" - Bug
Sun, Jun 5, 2011 at 11:17:41 PM | "Sheet Issue Date" - Bug
leothelionator
In Revit 2011, has anyone noticed that if you accidently screw up when entering a sheet date, you will end up deleting the entire sheet?!! I held down several sheets and simultaneously updated the Sheet Issue Date to 06/006/2011 and the sheets disappeared from the set, all because I accidently inserted on extra digit in the date (instead of 06/06/2011).  Worse still, I could not use the undo function to get them back!  Very disturbing.
I did however notice that the views were still present in the file, just not the actual sheets on which they were placed.
Mon, Jun 6, 2011 at 11:24:04 AM | "Sheet Issue Date" - Bug
emgeeo
3.5 Stars: 7 Votes
Haven't noticed it.
The important question - does all of the sheet information persist after the bug?
Mon, Jun 6, 2011 at 11:29:02 AM | "Sheet Issue Date" - Bug
leothelionator
None of the sheet information is present, only the views.  So if I go to the view that used to be on the sheet, I can look down at the Identity Data to see on what sheet the drawing is placed, but it turns out blank.
There's a chance my file may be showing signs of corruption.  Things like this always seem to happen as projects get older and copied day after day.  I tried creating a clean copy from Central and still had this problem.
Mon, Jun 6, 2011 at 11:36:31 AM | "Sheet Issue Date" - Bug
A good test would be to start a new project with one sheet in it and see if changing this parameter deletes the sheet.  If it does, then report it to AutoDESK.  Otherwise, you might look at your project file.
BTW - Did it delete the sheet from the index or delete the family from the sheet?  If it just deletes the famil, simply replace it and the views will still be on the sheets.
Edited on: Mon, Jun 6, 2011 at 11:37:42 AM
Mon, Jun 6, 2011 at 12:06:59 PM | "Sheet Issue Date" - Bug
leothelionator
I tried it on a new clean project and did not have the same problem, so I think there's something wrong with the Central File.  I even imported the same exact sheet family and did not have this problem on the new project file.
The Sheet family is still present, it did not get removed from the project.
Sheet Fields
Wed, Feb 20, 2008 at 3:40:26 PM
Sheet Issue Date Format
Tue, Apr 15, 2014 at 7:21:32 AM
Current Revision Date in sheet index
Mon, Nov 2, 2009 at 11:22:29 AM
Title block labels
Thu, Sep 23, 2010 at 9:54:31 AM
Tue, Apr 3, 2007 at 5:05:50 PM
Page generation time: 1.5773
