53 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Existing / Proposed
Thu, Jun 2, 2011 at 5:52:34 PM | Existing / Proposed
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Hey guys when I build the existing dwelling I right click on the ground floor and duplicate view so I can do the proposed but it changes the existing. Im guessing Im doing this wrong. Which is the correct way to have existing and proposed plans??
Revit 2018........
Fri, Jun 3, 2011 at 7:10:25 AM | Existing / Proposed
Use phases.  You can read about this in your HELP.
Fri, Jun 3, 2011 at 8:52:13 AM | Existing / Proposed
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Filters. Thanks for that this help is actually helpful not used to this I will be using it a lot thanks again.
Revit 2018........
Mon, Jun 6, 2011 at 11:43:54 AM | Existing / Proposed
emgeeo
3.5 Stars: 7 Votes
PHASING with a P!  Not Filters with an F.
Mon, Jun 6, 2011 at 4:19:02 PM | Existing / Proposed
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Phase Filter ..... with a P then a F
Revit 2018........
Existing and Proposed Problems
Tue, Jan 28, 2014 at 7:56:04 AM
Existing and proposed design
Sat, Mar 4, 2006 at 5:50:54 PM
Existing and proposed ground level
Mon, Aug 4, 2014 at 6:35:48 PM
Roof problems joining existing to proposed
Mon, Jan 21, 2013 at 9:15:05 PM
Existing door reused in proposoed phase
Tue, Oct 14, 2014 at 5:06:49 PM
Page generation time: 0.3800
