43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Component Modeled in place not cutting with section cut.
3 Posts No Rating |
I have created a component that does not cut when I use a section cut, how do I get it to cut properly?
3 Posts No Rating |
I have found that I had created it under a category which does not allow you to cut it with a section line. I also found that if you change the category type to one that allows it to be cut by a section line then you can get the results that are desired.
you also have discovered how the process works.
Edited on: Fri, Jun 3, 2011 at 5:44:09 AM
In Place furniture not cutting |
Wed, Oct 21, 2009 at 4:55:11 PM
Sections cut on mulitple sheets |
Fri, Jun 27, 2008 at 12:33:38 PM
"Paint" and In-Place Component Material Bug? |
Thu, Apr 14, 2016 at 2:47:43 PM
Cutting a section through a mass |
Sat, May 16, 2020 at 4:21:54 AM
cutting walls with void revolve component in revit 2011 |
Sun, Feb 10, 2013 at 10:13:05 PM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
