59 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Make perspective larger on a sheet Revit 2011
6 Posts No Rating |
How do you get the perspective view on a sheet, to make it larger?
If you drag a perspective onto a 24x36 sheet, the perspective is small.
If you drag a 3D view on a sheet, you can adjust the size by changing the scale of the drawing.
If you are in the perspective view, and you click on the crop box, you get an option "Size Crop", but that changes the size of the crop box.
You can render the perspective, save the rendering, go into the rendering view, click on the box, and you are able to adjust the size there, but I don't want to render at this time.
I did a search on this forum, but didn't find my answer so I am asking it here.
go to the perspective view, select the crop boundary, then from the option bar select "crop view". Now you can customize any size you want for your sheet
6 Posts No Rating |
Pchan,
You are somewhat right, there was an option that I didn't check. In this "Crop Region Size" Dialog box, you can change the "Field of View" but that only expands the crop box. However, if you select the "Scale (locked Propostions)", you can change the model crop size and then the view itself changes size, just as what I wanted.
That was exactly what I was referring
Perspective in sheets |
Mon, May 22, 2006 at 11:34:02 AM
What Determines the Width of a Perspective |
Tue, Jun 28, 2016 at 6:50:13 AM
Perspective Problem |
Fri, Jun 26, 2009 at 12:13:43 PM
Viewport larger then needed on sheet |
Wed, Feb 21, 2007 at 4:21:45 PM
Linework Blue Grip in Perspective? |
Wed, May 29, 2013 at 8:10:21 AM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
