57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Shaft Visibillity
2 Posts No Rating |
I have created a shaft through my first floor slab down to the ground floor, the shaft opening shows up as solid lines on the first floor but nothing is indicated on the ground floor, I wish to see the extents of the shaft as dotted lines on the ground floor plan, anyone help?
![4 Stars: 2 Votes](/images/stars_4.gif) |
Try editing your shaft opening and trace over it with Symbolic lines set to <Hidden>
![thetabest Avatar](user_avatar/231785.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
AND make sure your shaft extends into the ground floor slab, if it stops at the ground level, and your floor is ending at the ground level, they aren't intersecting, and thus it won't create the opening in your floor.
GL
Trent Best
Best Systems
the.tabest@gmail.com |
2 Posts No Rating |
Thanks, symbolic lines worked a treat
shaft cutting beams |
Tue, Jun 2, 2009 at 7:47:18 AM
A Floor That Can't Be Penetrated by Shaft Opening |
Thu, Feb 20, 2014 at 2:30:48 PM
Shaft Problem |
Thu, Jul 12, 2012 at 5:20:52 PM
Visible shaft in 3D view |
Tue, Aug 10, 2010 at 8:02:51 AM
Visibility of Shaft Openings in a detail view |
Fri, Apr 17, 2009 at 11:13:42 AM
Members: | 2080292 | Objects: | 23122 | Forum Posts: | 152264 | Job Listings: | 3 |
